xray xt8
xray xt8
heas seisukorras!
200 euro
115 euro kit
200 euro
115 euro kit
- 3333333333.jpg (80.9 KiB) Vaadatud 3379 korda
- 2222222222.jpg (56.56 KiB) Vaadatud 3379 korda
- 111111111.jpg (74.35 KiB) Vaadatud 3379 korda
Re: xray xt8
Turnigy TrackStar Waterproof 1/8 Brushless Power System 2100KV/120A
ESC Specs:
Continuous Current: 120A
Burst Current: 140A
Resistance: 0.00035ohm
Battery: 2-4 cells Lipo (6-14 cells NI-xx)
BEC output: 6V/3A
Motor type: Sensorless brushless motors
Running mode: Forward only or forward with reverse (user programmable mode)
Dimension: 43 x 39 x 33mm
Weight: 141g
Motor Specs:
Model: 4365 Sensorless
Kv: 2100
Cont Current: 80A
Peak Current: 140A
Max Power (15sec): 1680W
Winding: 2.0D
Resistance: 0.0086ohm
Weight: 315g
Diameter: 43mm
Length: 66mm
Shaft Diameter: 5mm
ESC Specs:
Burst Current: 140A
BEC output: 6V/3A
Weight: 141g
Motor Specs:
Kv: 2100
Cont Current: 80A
Peak Current: 140A
Winding: 2.0D
Weight: 315g
Diameter: 43mm
Length: 66mm
Shaft Diameter: 5mm
