E-Flite motor+esc
E-Flite motor+esc
Postitus Postitas andres-ures » 28.08.2012 12:01
motor http://www.e-fliterc.com/Products/Defau ... =EFLM1350H" onclick="window.open(this.href);return false;
Specifications:-
Type:Outrunner (for Ducted Fan use)
Bearings or Bushings:Bearings
Wire Gauge:18 AWG
Recommended Prop Range:66mm Fan Unit (3-blade fan)
Voltage:9.6V - 12V
RPM/Volt (Kv):3800
Resistance (Ri):.03 ohms
Idle Current (Io):1.80A
Continuous Current:25A
Maximum Burst Current:32A (15 sec)
Cells:3S Li-Po or 8-10 Cells NiMH/NiCd
Speed Control:25A - 40A Brushless
Weight:58g (2 oz)
Overall Diameter:28mm (1.10 in)
Shaft Diameter:.09 in (2.3mm)
Overall Length:30mm (1.20 in)
esc- http://www.e-fliterc.com/Products/Defau ... D=EFLA325H" onclick="window.open(this.href);return false;
30euro+post
Re: E-Flite motor+esc
Postitus Postitas andres-ures » 02.09.2012 15:42
up!
