Müüa laadija 200W 10.0A
ECO6-10 200W 10A 6S Bal/Dis/Cyc Charger w/ acc
Features;
Microprocessor controlled
High power and High performance circuit with maximum power of 200W
Delta-peak sensitivity (NiMH/NiCd)
Individual cell balancing
Li-ion, LiPo and LiFe capable
Ni-Cd and NiMH capable
Large range of charge currents
Fast & Store function, allows safe storage current
Time limit function
Input voltage monitoring. (Protects car batteries at the field)
Data storage (Store up to 10 packs in memory)
Spec.
Input Voltage: 10~18v
Circuit power: Max Charge: 200W / Max Discharge: 25W
Charge Current Range: .1~10.0A
Ni-MH/NiCd cells: 1~18
Li-ion/Poly cells: 1~6
Pb battery voltage: 2~24v
Weight: 480g
Dimensions: 143x119x42mm
Korra kasutatud 50 EUR
Features;
Time limit function
Spec.
Weight: 480g
- ECO6-10.jpg (100.15 KiB) Vaadatud 3734 korda
Viimati muutis doosan, 13.05.2011 21:58, muudetud 1 kord kokku.
Re: Müüa laadija 200W 10.0A
specis ei ole LiFe kohta midagi . Ma ei viitsi ka netist otsima hakata seda laadiat. Ehk paned siia infot rohkem. Kui LiFe laadimise võimalus olemas ja toiteplokk ka 220V siis 35€ võiks ära võtta.
MCD RR V4 SPORT
Kontakt: 53437917
Kontakt: 53437917
