MÜÜDUD. FG Sportsline 08 Porsche GT2
Sinuhobi
Sinuhobi
Postitus Postitas Sinuhobi » 21.04.2010 22:19
ENDISE KAUPLUSE NÄIDISE MÜÜK !
Legendaarne esimene On-road mudel millest sai alguse omaette võistlusklass
Masin sõitnud demona ühe paagi (seda teostasid Tanel Torger ja hr.Kaval)
Puudu, saatja, vastuvõtja ja gaasiservo (pildil olev ei tule kaasa kuid saab eraldi juurde osta 900.- rahaga)
Rehvid uued
Mingit juttu ka :
short Sportsline 04 Chassis and the short Competition Chassis with a width up to 400mm. Length 855mm, Width 405mm, Height 250mm, Wheelbase 465mm With the new Sportsline 04 we enable you a reasonable start in the 1:5 On-Road model scene. As we don’t know where and how you would like to use your car model we offer you some Tuningkits to a special price. So it’s up to you at which price and with which equipment you want to begin. The special price of the Tuningkit is only guilty in combination with the purchase of a Sportsline chassis. Technical description of the 1:5 Sportsline 04 Chassis up to 400mm width: The models are built on a 4mm alloy chassis with double wishbones at front and rear axle. All borings of the alloy chassis are countersunk to prevent the screw heads from bearing out. The models are serial equipped with the 2-damper front axle which guarantees an optimal traction of both front wheels. At the front and rear axle king pin angle, trailing effect and toe-in can be adjusted by means of track rods or respectively adjusting screws with right-/ left-handed thread. Further equipment points are differential gear, easy-running FG ball drive, alloy brake caliper with big brake disk, oil-pressure shock absorbers with volume control and external adjusting ring for the initial stress of the springs. All rotating parts as shafts, axles, clutch bell a.s.o. are supported by ball bearings. The models are equipped with a powerful 23ccm combustion engine which runs with a2-stroke petrol-oil mixture. One tank filling gives you about 45 minutes driving fun. The power is transmitted over the well-experienced system: engine - 2-block clutch over radial tooth wheels on to the rear axle which is equipped with the bevel differential gear with pluggable axles. RC-plate with receiver box. The tires are ready glued.
RAHA KÜSIME : 6000.00 EEK (koos kõikide kehtivate maksudega)
Muidu maksab kuskil 12900.00 EEK
Auto tutvumiseks HOBIMAAILMA kaupluses, tehingu ja lisaküsimuste osas pöörduda [email protected]
Suvi tuleb, varsti saab rehvi kuumutada :)
Viimati muutis Sinuhobi, 24.04.2010 21:00, muudetud 1 kord kokku.
Sinuhobi
Sinuhobi
Re: M. FG Sportsline 08 Porsche GT2
Postitus Postitas Sinuhobi » 21.04.2010 22:24
Anger
Postitus Postitas Anger » 22.04.2010 17:47
Mis mudeliga tegu on? Teema pealkirjas on spotline 08, aga kirjelduses 04...
FG Competition EVO 07; FG Sportline
Sinuhobi
Sinuhobi
Postitus Postitas Sinuhobi » 22.04.2010 19:37
Anger kirjutas:Mis mudeliga tegu on? Teema pealkirjas on spotline 08, aga kirjelduses 04...
Uue hinnakirja järgi 08 vana järgi 04
Sinuhobi
Sinuhobi
Re: MÜÜDUD. FG Sportsline 08 Porsche GT2
Postitus Postitas Sinuhobi » 24.04.2010 21:01
Teema LUKKU !
Õnnitleme uut omanikku !
