M: FG On-Road Truck (Sportsline 04 Chassis Atego Truck)
Sinuhobi
Sinuhobi
Postitus Postitas Sinuhobi » 21.04.2010 21:58
ENDISE KAUPLUSE NÄIDISE MÜÜK !
Tooted 3404 + 3064 Sportsline 04 Chassis Atego Truck/ 23ccm
Pikkus vastavalt kerele, Laius 435mm Kõrgus vastavalt kerele, Sillavahe 535mm
Elektroonika tuleb soetada eraldi
This model is built on a 4mm alloy chassis with double wishbones at front and rear axle. All borings of the alloy chassis are countersunk to prevent the screw heads from bearing out. The chassis is serial-equipped with a 2-damper front axle which guarantees an optimal traction of both front wheels. At front and rear axle you can adjust king pin angle, trailing effect and toe-in with track rods or respectively adjusting screws with right/ left-handed thread. Further equipment points are: differential gear, easy-running FG ball drive, alloy brake caliper with big brake disk, oil-pressure shock absorber with volume control and external adjusting ring for the initial stress of the springs. All rotating parts such as shafts, axles, clutch bell a.s.o. are supported by ball bearings. The models are equipped with a powerful 23ccm combustion engine which runs with a 2-stroke petrol-oil mixture. Each tank filling gives you about 45 minutes driving fun.
RAHA KÜSIME : 6000.00 EEK (koos kõikide kehtivate maksudega)
Muidu maksab kuskil üle 13000.00 EEK
Auto tutvumiseks HOBIMAAILMA kaupluses, tehingu ja lisaküsimuste osas pöörduda [email protected]
Suvi tuleb, varsti saab rehvi kuumutada
PS! Kaasa minu vana Alfa Romeo kere (kui vahetad rehvid saad ka mingi modimise käigus ka selle paigaldada)
