MULTIPLEX uudised
Moderaator: Sinuhobi
Sinuhobi
Sinuhobi
MULTIPLEX uudised
Postitus Postitas Sinuhobi » 31.03.2010 12:05
Saksa laos nüüd saadaval mitmeid Multiplex uudistooteid.
Lühike ülevaade servodest :
digi5 - the new MULTIPLEX servo electronics
These servos incorporate MULTIPLEX digi5 servo electronics, which is a further development of the digi4 servo circuit. Existing characteristics have been retained and further improved, and new ones added. Many features of digi5 electronics can be programmed using the MULTImate universal test and programming device (# 8 2094), and the new circuit offers a significant improvement in resolution. That means even more precise control, especially with modern RC systems with digital transmission technology (e.g. MULTIPLEX M-LINK or M-PCM). Another special feature is the option of programming what is known as an OLP, which protects the servo from overload conditions.
The following features are programmable:
• Overload protection (OLP)
• Resolution / operating travel (90/180°)
• Deadband
• Neutral point
• End-points
• Direction of running, transit speed
• FAIL-SAFE position and FAIL-SAFE ON / OFF
TITAN SHV digi5 TORQUE servo 6 5153 HIND: 1720.- eek
Servo 65153
Powerful premium digital high-torque servo with robust steel gears for use in large-scale models.
The plus-points:
• New digi5 servo electronics for maximum positional accuracy
• Wide operating voltage range of 4.8 V ... 8.4 V
• Durable, high-strength steel gears
• High-performance bell-armature motor
• Aluminium heat-sink
• Two ballraces, bushed gearbox shafts
Specification
Dimensions (L x W x H) 40 x 20 x 38 mm, Weight 68 g, Gearbox Steel, Ballraces 2, Multi-wiper pot yes, Indirect-drive pot yes
Torque @ 5 NiXX cells / 2S LiPo* 190 / 220 Ncm, Holding power @ 5 NiXX cells / 2S LiPo* ** 200 / 230 Ncm
Speed for 40° @ 5 NiXX cells / 2S LiPo* 0.15 / 0.12 sec.
TITAN THV digi5 HIGH TORQUE servo 6 5152 HIND: 2346.- eek
Servo 65152
Premium high-torque digital servo with ultra-robust titanium gears.
Aluminium centre case section provides effective cooling for the motor and electronics.
The ideal servo for use in large-scale models, and any application where extreme power is required.
The plus-points:
• Durable, ultra-strong titanium gears
• Programmable using the MULTImate (# 8 2094)
Specification
Dimensions (L x W x H) 40 x 20 x 38 mm, Weight 68 g, Gearbox Titanium, Ballraces 2, Multi-wiper pot yes, Indirect-drive pot yes
Torque @ 5 NiXX cells / 2S LiPo* 260 / 300 Ncm, Holding power @ 5 NiXX cells / 2S LiPo* ** 240 / 270 Ncm
Speed for 40° @ 5 NiXX cells / 2S LiPo* 0.10 / 0.08 sec.
TITAN THV digi5 HIGH SPEED servo 6 5151 HIND: 2346.- eek
Servo 65151
Premium ultra-fast digital high-speed servo of the 20 mm class for the most demanding applications.
The plus-points:
Specification
Torque @ 5 NiXX cells / 2S LiPo* 120 / 145 Ncm, Holding power @ 5 NiXX cells / 2S LiPo* ** 150 / 175 Ncm
Speed for 40° @ 5 NiXX cells / 2S LiPo* 0.05 / 0.04 sec.
Kõik muud uudistooted saate alla laadida SIIT
