M: Tamiya TEU-101BK ESC
heido
Postitus Postitas heido » 31.01.2010 19:07
Müüa pealkirjas toodud isend, harjadega mootorile.
Tamiya, 250eeku
FEATURES:
Compatible with Tamiya 540 and Sport Tuned stock motors
Reverse function can be changed to brake for races where reverse is not allowed
Compatible with Futaba, Tower Hobbies, Tamiya, KO, JR and Airtronics
Z connectors
Set button allows adjustment of maximum forward and reverse throttle trigger settings
INCLUDES:
One Tamiya Forward and Reverse Electronic Speed Control with motor
connectors, Kyosho style battery connectors, receiver connector
and receiver switch pre-installed, instruction sheet
REQUIRES: Installing in vehicle and connecting motor and battery
SPECS: Length: 1.6" (40.7mm)
Width: 1.4" (36.8mm)
Height: 0.88" (22.5mm)
Weight: 1.9oz (54g)
Control System: High frequency drive
Max Continuous Current (FET Spec): Forward 60A, Reverse 60A
Power Supply: 7.2V (with 6 cells
Output Voltage for Receiver: 7.2V
Output Current for Receiver: 1A
Viimati muutis heido, 24.03.2010 12:30, muudetud 1 kord kokku.
HPI E-Savage brushless
HPI Blitz 2WD SCT
crawl.ee
heido
Re: M: Tamiya TEU-101BK ja Traxxas XL5 Waterproof ESC
Postitus Postitas heido » 24.03.2010 10:57
:arrow:
HPI Blitz 2WD SCT
crawl.ee
heido
Re: M: Tamiya TEU-101BK ESC
Postitus Postitas heido » 24.03.2010 16:04
Ja teema lukku.
HPI Blitz 2WD SCT
crawl.ee
