Hitec saatja antenn Hind : 118.-eek tk
Multiplex Servo Titan MG Tigi 4 korpus Hind : 162.- eek tk
Traxxas esiõõtsad 5331 (sobivad üsna mitmele mudelile) Hind: 249.- eek
Traxxas 4981 Ring gear, 37-T/ 13-T pinion/ diff carrier Hind: 374.-eek 1 komplekt
Traxxas 5334 Axle carriers, left & right (1 each) Hind: 249.- eek komplekt
Hitec servo hs-645 mg Hind: 687.-eek tk
The HS-645MG represents a new generation of Hitec servos. Utilizing our unique MP and Alumite gear train technology the HS-645MG has our famous guaranteed to be un-breakable gear train. The powerful HS-645MG is perfect for those applications that demand a high torque servo.
Lager/Bearing 2 Kugellager/Ball Bearing
Geschwindigkeit/Speed 4,8/6V (sec/60°) 0.24/0.20
Drehmoment/Torque 4,8/6V (Ncm) 77/96
Standing Torque 4,8/6V (Ncm)
Masse/Dimension (LxBxH) 40.6x19.8x37.3
Gewicht/Weight (g) 55.2
Motor Eisenanker/Standard
Sonstiges/Misc
Getriebe/Gear Metall/Metal
Control System +PULSE WIDTH CONTROL 1500usec NEUTRAL
Operating Voltage Range 4.8V TO 6.0V
Idle Current mA 8.8/9.1
Running Current 4,8/6V (mA/60°) 350/450
Stall Current 4,8/6V (mA)
Dead Band Width 8usec
Operating Travel
Direction CLOCK WISE/PULSE TRAVELING 1500 TO 1900usec
Potentiometer Type
Amplifier Type
Horn Gear Spline
Splined Horns
Connector Wire Legth 300mm
Connector Wire Strand Counter
Connector Wire Gauge
