Müün siis hiljuti ostetud VRC-3 USB-adapteri. Ise maksin 302kr, küsin kõigest 299kr (hinnasula!)
Miks müün? Sest nagu all jutus kirjas, siis läpakas+3PK+FASST R603FS kombinatsioonis ei tööta. Tõenäoliselt kõigi teiste 2.4GHz süsteemidega siiski toimib. 40MHz ja PPM-iga toimis kenasti. Windowsis Game Devices all "joystickuna" ehk siis saab erinevaid teisi mänge kah juhtida sellega...
Control VRC with your own transmitter, it can't get any more realistic than that. All the settings you make on your transmitter, like trims, exponential steering and brake settings will directly be noticable in VRC.
The VRC-3 USB adaptor works independent of the brand or frequency of your transmitter as it only uses the standardized servo output signals and translates these to the standardized game controller input using the HID protocol.
The VRC-3 therefore works on all 27-40-53-72 MHz and 2.4GHz sets. (With Futaba only FM and PPM modes can be used).
Your receiver is powered through the VRC-3 USB adaptor which receives its power from the USB port of your computer. Do not connect a receiver battery pack.
Problems are reported with Futaba 3PK and Futaba R603FS receiver combination, which may be caused by too low voltage from the USB device.
