Kaasa saab progemise kaardi!
mõned spec'id:
1 Output: Continuous 100A, Burst 120A up to 10 Secs.
1.2 Input Voltage: 2-6 cells lithium battery or 5-18 cells NiCd/NIMh battery.
1.3 BEC: None.
1.4 Max Speed: 210,000rpm for 2 Poles BLM, 70,000rpm for 6 poles BLM, 35,000rpm for 12 poles BLM. (BLM: BrushLess Motor)
1.5 Size: 78mm (L) * 55mm (W) * 15mm (H).
1.6 Weight: 120g.
2 Features
2.1 Safety Arming Feature: Regardless the throttle stick position, the motor will not spin after battery connected.
2.2 Throttle Calibration: Throttle range can be configured to provide best throttle linearity, fully compatible with all market available transmitters.
2.3 Programmable Items:
Brake Setting: brake enabled / brake disabled.
Battery Type: Li-xx(Li-ion or LiPo) / Ni-xx(NiMh or NiCd).
Low Voltage Protection Mode(Cutoff Mode): Gradually reduce the output power / Cutoff the output power.
Low Voltage Cutoff Protection Threshold (Cutoff Threshold): low / medium / high.
Start Mode: normal / soft / very soft.
Timing: low / medium / high.
Reset: reset all the programmable items to its default setting.
2.4 Full Protection Features: Low voltage cutoff protection / over-heat protection / throttle signal lost protection.
3 Advantages
3.1 Military standard capacitor with extreme low resistance is used at voltage input section, this will increase the ability of prevention of unwanted RF Noise/ Interference during flying.
3.2 Extreme low resistance PCB is used at power output section, the total thickness of copper sheet is more than 0.7mm, so the whole ESC has super current endurance capability.
3.3 Big heat sink has a very good cooling effect.
3.4 Compatible with Hobbywing's Program Card.
regu kvaliteedis pole mõtet kahelda tegemist on tõesti korraliku isendiga!
Mõned Live pildid paigaldatud mudelile
Ventikas on peale pandud igaks juhuks kuid selle vajadus on NULL, panin algusest kohe peale kartes ehk kuumeneb, müün regu ilma ventikatta
Teema kus on juttu olnud sellest on siin:
http://foorum.hpi.ee/viewtopic.php?t=1923
Eerik
5068569
