M:MOOTOR!(LiPower 480 Pro )
imelik
Has thanked: 1 kord
Postitus Postitas imelik » 29.01.2012 00:54
Müüja siis mootor.
Andmed:
LiPower 480 Pro
Li-Power electric motors
Powerful standard motors with high torque.
Operating voltage: 3,7 - 8,4 V
Nominal voltage: 7,4 V
No-load current: 0,85 A
No-load rpm: 17.500
Max. efficiency: 69 %
Cur. drain at max. ef.: 5 A
Current drain, stalled: 24 A
Dimension mm: 27,7 x 51,0
Shaft: 2,3 mm
Weight: 92 g
6 EUROT!!
