Sai omale tellitud laadija , mis lubab mul oma akusid ka 2C vooluga laadida, siis jääb vana aparaat üle.
Ehk on vaja kellelgi just sellist komplekti
Laadija: Robbe Power Peak Compact BID 12V. Hind : 800.-
http://www.mscomposit.com/electronics/c ... t-bid.html
Laeb ta pea kõiki akusid. kuni 5A vooluga, 10 aku mälu jne...
Balancer : Robbe Lithium Top Equalizer S6 (No. 8492). Hind: 350.-http://www.mscomposit.com/electronics/c ... 300ma.htmlThe Universal Charger
A compact, low-cost charge - discharge station with battery management for NC / NiMH batteries with 1 .. 14 cells, LiPo packs containing 1 .. 5 cells, and 2 .. 12 V Lead-acid batteries.
Longer description
Two versions are available:
1. Power Peak Compact BID as 12 V device
2. Power Peak Compact Duo Power BID, as
12 V device plus separate 100 - 240 V 5 A switch-mode mains power supply.
Ja Fullymax 3300mAh 7,4V 2S Li-Po aku. Hind: 350.-Over-voltage cut-off: the device features a safety function in the form of over-voltage termination, which is triggered if the voltage of any one cell in the pack rises to 4.3 Volts (LiPo), 4.2 Volts (LiIo) or 3.9 Volts (LiFe). If used in conjunction with suitable battery chargers, the Equalizer automatically reduces the charge current when the cells reach a voltage of 4.25 V (4.15 V / 3.85 V). The battery must be connected to the TOP Equalizer using a sensor lead. robbe LiPo batteries are already fitted with the appropriate connector (JST-EHR).
Features:
2 ... 6 LiIo cells (3.6 V / cell), LiPo cells (3.7 V / cell) or LiFe batteries (3.3 V / cell) with a suitable LiPo charger, e.g. Power Peak Compact, Infinity 3.
The Equalizer function can also be used separately, i.e. without a battery charger.
http://www.hobbybox.ee/?k=1&t=845 (kuna ma sealt enam 3300mAh akut ei leidnud siis tuleb leppida seal selle väiksemaga, aga ülejäänud jutt on ju sama
Kogu selle stuffi tahaks müüa korraga.. aga kui kõigile on ka eraldi ostja olemas, siis läheb ka jagamiseks
Korraga ostes teeme 1400.-
Martti.
