Sold
kevinh
Sold
Postitus Postitas kevinh » 02.03.2017 12:53
Müügiks siis praktiliselt uus monitor Eachine 5802s
Pildid
https://1drv.ms/f/s!AncuSflh9UWgjl782Ni3CFU43UqM
Description:
Brand Name: Eachine
Item Name: LCD5802S Monitor
Built-in 5.8Ghz Dual diversity receiver automatically for best reception
Built-in 2CH 5.8Ghz AV output and 1CH AV input
Built-in high performance Li-POLYMER Battery: 2000mAH/7.4V
Work status OSD display : RSSI indication ; Battery indicator;Channel indication
A key to automatic signal search
Support Chinese and English menu
Sensitivity: -90dBm
Screen size:7”
Screen type:TFT LCD Screen/long life, LED backlight
Resolution: 800*480
Brightness: 600cd/m2
View Angle:140/120degree (Horizontal/Vertical)
Size:180mm x 120mm x 50mm(Note:Sunshield height:28mm)
Working Voltage: DC 7~16V
Power Consumption: max 650 mA @12V
Battery charging current : 850mA @12V ( max )
Working temperature: -10℃~+ 65 ℃
Connectors:RP-SMA female(outer needle)
Antennas Connectors:RP-SMA male (inner hole)
Huvikorral kirjuta kevinharjakas@gmail.com või helista 555 23 I2I
Hind 80€
Asub Pärnus, mujale saadan postiga.
