Futaba S9253:
Sobib kopteri sabaservoks. http://www.servodatabase.com/servo/futaba/s9253" onclick="window.open(this.href);return false;
20.-
![Pilt](http://img821.imageshack.us/img821/6222/img6790d.jpg)
Quick ep-8
Alumiiniumist pea ja sabarootori mehhanismid, süsinikraam ning sabatoru, karbitäis varuosi ( raami-, rootoridetailid, rihmad jne.) Mootori saab kaasa, kui ma ei eksi oli tegu Neu toodanguga.
60.-
Infot:
Specifications:
- Main Rotor Diameter: 890mm
Head: Metal Hub single spindle
Blade Grips: Metal
Pitch Arms: Metal
Washout Unit Arms: Metal
Swashplate: Metal
Main Shaft: 6mm
Bearing Blocks: Metal
Flybar: 3mm
Flybar Control Arms: Metal
Tail Boom Length: 445mm
Tail Rotor: Belt driven
Tail Rotor Blades: Plastic
Frames: Rigid aluminum
Fins: Plastic, new mounts
Canopy: Fiberglass
Weight without Motor: 650g
Ready-to-fly Weight: 1200 - 1500g
Main Rotor Blades: Standard 400mm
25T Tail Slow Down Gear
Updated Tail Pitch Slider
![Pilt](http://img194.imageshack.us/img194/2122/img6803v.jpg)
![Pilt](http://img39.imageshack.us/img39/240/img6796pb.jpg)
![Pilt](http://img705.imageshack.us/img705/3740/img6792y.jpg)
![Pilt](http://img541.imageshack.us/img541/1526/img6817t.jpg)
MultiWii SE V2.0:
Infot: http://www.hobbyking.com/hobbyking/stor ... _FTDI.html" onclick="window.open(this.href);return false;
müüdud
![Pilt](http://img62.imageshack.us/img62/359/img6778y.jpg)
Veel kola, paku hind (müüdud)
![Pilt](http://img818.imageshack.us/img818/5905/img6782o.jpg)
